Two signals at two waveform graphs
Hello Everyone!
I got some problems with my software for data acquisition.
I got two signals and I have to show two signals at two different Waveform Graph.
How to seperate signals?
Message 1 of 10
(3,700 Views)
Index Array.
Message 2 of 10
(3,665 Views)
Where I have to put Index Array?
I can't find examples for using index array to waveform graphs
Message 3 of 10
(3,658 Views)
You index the 2D array that is coming out from the DAQmx Read.
It is irrelevant whether there is a specific example for a DAQmx Read. A 2D DBL array is always a 2D DBL array whether it is wired to a graph or something else. You need to read the help for the DAQmx Read in order to know whether to read rows or columns.
Message 4 of 10
(3,651 Views)
I read DAQmx help and what I know is that Each row corresponds to a channel in the task. Each column corresponds to a sample from each channel.
I really don't know how to wire Index Array... Can you explain it to me, please?Smiley Sad
Look at the attachment, is it ok?
Message 5 of 10
(3,636 Views)
Accepted by Jurij
There is an input called 'array'. Simply wire this to the 2D DBL array. Drag the bottom of the Index Array down so that you have a second subarray output. Wire up your graphs. Done. No need to wire anything to the index inputs.
Message 6 of 10
(3,632 Views)
Thank you very much
Message 7 of 10
(3,625 Views)
I got question for you - why I don't need to wire anything to index inputs?
Message 8 of 10
(3,610 Views)
The first index input defaults to 0. Each time you drag it down, the index input is automatically set to n+1. You can also start at an index other that 0. For example, you wanted rows 2,3,4,5, you would wire 2 into the first index input and after dragging it down to get an additional 3 inputs, you would skip wiring the values 3,4, and 5.
Message 9 of 10
(3,597 Views)
Thanks, now I get it Smiley Happy
Message 10 of 10
(3,583 Views)
