Triggering in Labview using Analog Input Signal
Hi NI community,
I am trying to acquire an Analog Input signal using LabVIEW (2010). I am using input analog signal (like sine wave) as a triggering source. Also I want to record the same wave/pulse.
How can I do this operation?
I am using NI-PXIe-6124 card.
(3,299 Views)
What is the problem? The DAQ? The triggering? The logging?
What do you have and where did you fail?
(3,274 Views)
Thanks for your response.
I am using the start trigger option. When I use rising edge and set trigger level, the data previous to trigger level is not recording and the intial pulse is not capturing completely.
so I want to record some data prior to trigger so that I can get the full pulse.
(3,271 Views)
I'm not sure if the hardware is capable of doing that.
Here's the scheme I used (with different HW).
1) Start capturing data. Store it in a memory buffer. Data beyond the pre-trigger time can be removed from memory. Usually, the buffer is a 'circular buffer' type.
2) Analyze the data (in a parallel loop of some kind), to see if there's a trigger.
3) If so, store the buffered data, and wait for the post trigger data to come in (while storing it as it comes in).
(3,261 Views)
