Trigger in LABVIEW 2014
I am using a state machine to setup conditions on a UUT. Apply power..send a "turn on signal"..etc using a PXIe6345 Analog outs.  All the while I need to monitor an analog in to see if during the setup I inadvertently caused the UUT to  send a pulse on another output.  I'm thinking this is a little like a trigger on a scope.  I can do things elsewhere on other analog ins/outs while constantly monitoring Ch b ( my trigger) to see if a trigger occurred.  if it did do something.  Is this parallel looping?  Any suggestions on how to accomplish w a DAQ?
(2,838 Views)
Most of the signals you describe (Power, Turn On Unit, UUT sends a pulse) sound binary (on or off), hence more "digital" in nature than analog.  Why not use the DIO lines and have a little free-spinning loop running at whatever rate you need to get the timing accuracy you want monitoring them?  That is, assuming you can't just use the digital signals directly to trigger the analog functions of the card ...
(2,806 Views)
My stumbling block is the parallel loops.  Couldn't find any examples.  Any suggestions?
Thanks.
(2,770 Views)
Sure sounds like parallel processes to me. It not always need to be loops. If you have two sequences (e.g. VIs behind each other in stead of a state machine) you can execute them in parallel without any loop at all!
Typically, you'd make three processes. One handling DAQ (perhaps two loops: one for input, one for output) and then as many processes as required. Those other processes would be communicating with the DAQ process. Typically through channel wires, queues, user events, FGV, and what not...
(2,762 Views)
If you attached your State Machine VI (as a VI, not as a picture of part of the VI, or, even better, as a .zip file resulting from compressing the folder containing the entire LabVIEW Project), we'd be able to see what you are actually doing and make more useful, and, I hope, helpful, suggestions.
(2,760 Views)
