Tree control ActiveItemRowNumber
I created a Tree control.
I added three items
--- 12
--- 23
--- bcd
Then I highlight  the row containing 23, then click the Run button.
The property ActiveCellRowNumber doesn't changes. I tried all three items.
(4,686 Views)
Use the tree termal to read highlighted item.
Or you can use property => value.
ActiveItemRowNumber can be used to change text color, font, etc. without interfere with tree value.
George Zou
(4,657 Views)
Before Reading the Active Row Number you need to provide the active Tag.
Check this out!!!!
(4,622 Views)
Check this out!!!!
But if the user selects the active row, why doesn't the ActiveItemRowNumber change?
(4,603 Views)
Accepted by njacacia
Because the user doesn't select the active row.  The user selected item becomes the value of the control.  The snippet PalanivelT provided shows you how you can get the row number for the selected value.  As zou stated, the ActiveRowNumber is really only for selecting a row to apply property changes.
(4,587 Views)
The Property of Active Row Doesn't gets triggered based on your selection, it triggers once Tag is getting activated (By Writing Tag Name).
(4,570 Views)
