Tree Controls
When I create a tree control the default value of the terminal is a string.  How do I make the default value an array of string?  I currently have a tree control that is an array of string and I cannot determine how it got that way and I would like to replace it with a Silver control.
(3,940 Views)
Accepted by topic author ww.brown
Hi ww brown,
change the selection mode of the tree to "0/1 or more objects"…
(3,900 Views)
Thanks!  Using Selection Mode of "0 or More Items" gave me the desired array of string.  It is curious how the original tree produced this result with Selection Mode set to "0 or 1 Item".
WB
(3,873 Views)
Then you should mark Gerd's message as the solution to your problem.
(3,867 Views)
