Transpose 1D Array
@paul_cardinale wrote:
It's a real built-in LabVIEW function.  The output is the same as the input.  I can't imagine why it's there (except to give us something silly to talk about).
Then obviously it's a VI to eliminate all the questions on the forums about how to transpose a 1D array.  That's too funny.  Smiley Very Happy
aputman
Message 21 of 32
(3,585 Views)
It might be a curiosity amplifier.
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Now also available on VIPM
Message 22 of 32
(3,580 Views)
Its "Wire Equivalent Code?"
"Should be" isn't "Is" -Jay
Message 23 of 32
(3,579 Views)
Helps avoid all those nasty empty flat sequence structure frames?
GCentralI'm attending the GLA Summit!
Message 24 of 32
(3,575 Views)
where did you find it? What palette, in what version of LabVIEW?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 25 of 32
(3,570 Views)
@altenbach wrote:
@aputman wrote:
This is a standard matrix function and probably has little to do with this discussion.
It doesn't take a matrix as input, only a 1D array.
The one quoted here does. I already commented on your 1D transpose function earlier.
Message 26 of 32
(3,570 Views)
No, it doesn't take a matrix:
It only takes a 1D array.
Message 27 of 32
(3,524 Views)
I was talking about the snippet posted by aputman, which is not the same as yours.
Message 28 of 32
(3,516 Views)
It's not on a palette, but you can create it with scripting.
Here's a bunch of other stuff not on any palette.
Message 29 of 32
(3,494 Views)
 I think you are missing several primitives that have been known to the public like the almost equal (that is unstable) Text to/from UTF, Coerce to Type, Leak/Unleak Variant, and Recompose DVR/Variant.  That last one has all kinds of warnings not to use it and even has a skull and cross bones icon.  To be fair some of those might have been removed in newer versions of LabVIEW, but some are still there.
The decorations you found look like stuff mostly from the DSC toolkit, including the neat pipes, and various filling images and valves.  DSC has a really cool Image Navigator for making industrial looking controls.  The other controls you found could be handy for sure.
Message 30 of 32
(3,473 Views)
