Translating a string into a number (Homework Help)
@Paddle_to_the_sea21 wrote:
I have saved it for the 2016 version hopefully this works!
It is extremely inefficient and tedious to maintain a case structure with 11 cases, Not really scalable and many places of buts to hide.
See if this can give you some ideas.
(And yes, you could create a map for even simpler code).
Message 21 of 26
(809 Views)
Accepted by Paddle_to_the_sea21
Here's how that could look like!
You can figure out how to create that map constant from the earlier array of clusters 😄 )
Message 22 of 26
(805 Views)
@altenbach wrote:
For a map with 10 elements, the difference between a plain search O(N) and a map O(logN) does not justify the map overhead. That only starts to matter for larger collections. A LUT is O(1) and the max size here is tiny (256 elements) that can be constant folded.
It's not just the size of the collection. It's also the number of times it's called.
For this homework assignment it's completely irrelevant, but still a fun topic.
Message 23 of 26
(772 Views)
I like the OP solution simply because they wrote it themselves.  It's a successful effort in line with their experience.
Bill
CLD
(Mid-Level minion.)
Message 24 of 26
(752 Views)
Yes, the OP clearly showed some effort and the remaining problems (e.g. the empty string confusion) have been solved. Once the code does what it should, we can offer improvements and comments, just as a learning experience and encouragements to dive just a little deeper. 😄
Basically, we can show that sometimes less is more. Scalability, (e;g; ease of making changes if the cypher changes), readability are all useful foundations that will help making 100x more complex programs possible with only 5x the effort. 😄
Message 25 of 26
(732 Views)
Oh, yes.  I completely agree.  I just hope they use their homegrown solution because they earned that one.  🙂
Bill
CLD
(Mid-Level minion.)
Message 26 of 26
(714 Views)
