03-25-2013 12:50 PM
I have a signal which ramps at 0.05 volts/second. During this state, there is a possibility that the ramp rate
exceeds the 0.05 v/sec. operation (runaway condition). Does anyone have any ideas about how to track this and
respond to the runaway condition?
03-25-2013 12:53 PM
How is the signal being generated? How are you sampling it?
You could just take the difference between two samples and if their rate is out of a certain range, take care of it.
03-25-2013 12:55 PM
100ms/sample and a 20 sample moving average for smoothing.
03-25-2013 01:07 PM
Are you using point by point sample generation or generating the samples as an array. Any case Tim's solution is the simplest and would work good.
03-25-2013 02:29 PM
I would suggest you to mark crossrulz reply as a solution. 🙂
