Tracking a ramping signal and checking for range thresholds
I have a signal which ramps at 0.05 volts/second.  During this state, there is a possibility that the ramp rate
exceeds the 0.05 v/sec. operation (runaway condition).  Does anyone have any ideas about how to track this and
respond to the runaway condition?
(3,091 Views)
How is the signal being generated?  How are you sampling it?
You could just take the difference between two samples and if their rate is out of a certain range, take care of it.
(3,090 Views)
100ms/sample and a 20 sample moving average for smoothing.
(3,087 Views)
Accepted by PokeChop
Are you using point by point sample generation or generating the samples as an array. Any case Tim's solution is the simplest and would work good.
(3,083 Views)
I would suggest you to mark crossrulz reply as a solution. 🙂
(3,063 Views)
