Time inside Timed Loop
I have a timed loop where I perform some calculations and events and then I save some data in a file, the loop is executed each 1 second.
What I want is to save the data I colected in the loop, each 10 seconds, but I am not able of achive it.
How could I do it?
I add an example of the problem I'm trying to describe.
Example1Example1
(2,610 Views)
Hi yavs,
you might save the data on every 10th iteration. Or change the iteration time to 10s…
What exactly have you tried?
(2,583 Views)
Accepted by yavs
You drew a decorative box around the code in question.  Imagine if you had draw a case structure instead?
That along with Gerd's advice will get you there.
(2,574 Views)
