how to reduce precision of a slider upto 3 decimal points
Hello Good Afternoon,
I am generating a floating number through a slider
for example 1.234567 i want to do a precision that the output should be scaled upto 3 decimal points like 1.234 i am wishing to get this output is there any simple way of doing it can some please help with an example
(2,534 Views)
Hi Anjaney,
a DBL value is good for ~15 decimal digits.
All you can change is the appearance on the front panel by applying some formatting rules. Set the slider to show just 3 decimal digits.
(2,523 Views)
You should be able to set the controls properties to have step of 0.001. It's not perfect since floats have their limitations, but it should be close enough. As Mentioned, you should also set the display to 3 decimals.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,492 Views)
