Tilt a boolean square led
I want to tilt a square led, it seems simply but I do not know how to do it.
I can change the height and widht but no the angle.
I attach a picture where I want to put a led from the center of an hexagon until the perimeter.
Message 1 of 12
(5,948 Views)
Not sure that you can.
One option would be to replace the indicator with a picture ring containing 6 images. 3 angles of OFF and 3 angles of ON.
Make the picture ring's frame transparent, and the unused areas of the image transparent, it should look how you expect.
You can then add the logic to transition between the states as required.
0xDEAD
Message 2 of 12
(5,943 Views)
Where can I find that picture ring that you say? I do not follow you, I do not understant.
Message 3 of 12
(5,933 Views)
Or use a picture indicator.
You can grab the image of a square led rotate it and place it in the picture as needed.
See this post where Christian showed us how to rotate an image.
RotateVase
You can the image of the Boolean using an invoke node get image.
Ben
Message 4 of 12
(5,931 Views)
https://www.youtube.com/watch?v=AmDLCsnOegw
This video shows you how. Make 6 different pictures in the ring and switch between them as needed.
0xDEAD
Message 5 of 12
(5,919 Views)
Right-click on the boolean, select Advanced -> Customize ... Click on the little wrench on the toolbar (becomes tweezers). Now you can import images for the different states.
Message 6 of 12
(5,867 Views)
All you need is three different booleans. A rectangular (3,4) and two with the picture of the rectangular LED tilted 60 (2,5) or -60 (1,6) degrees (rotate in a drawing program and import into a button). Now arrange them as outlined with the dashed lines. You can even arrange them in a cluster.
Message 7 of 12
(5,821 Views)
Of course it also depends what you need this for. If only zero or one LED can be on at the same time (e.g. a direction indicator), you can make a picture ring with 7 images, each containing all LEDs in a single picture. If all LEDs can be ON or OFF independently, you have 64 different states and I would go with my solution above.
Message 8 of 12
(5,810 Views)
You might also consider using rectangular LED and make an overlay image that has transparent 'windows' with the shape of LED led you would like.
Message 9 of 12
(5,783 Views)
Accepted by topic author aitorplaza
Here is an example of an overlay (VI attached).  I would usually make this a cluster and then typdef it.  I would also consider replacing the LED with a color box to allow for more states/colors if needed.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 10 of 12
(5,772 Views)
