Tilt a boolean square led
hThat is perfect. I would like to know how you got it because a can not see the procedure on the block diagram or front panel.
How did you rotate the square LEDs??
Thanks in advance.
Message 11 of 12
(1,143 Views)
If you look at the front panel you will notice that I did not rotate the buttons just simply covered them with a png that has transparent windows so that you only see the rotated window portion.  This is much like how old pinball machines worked or your dash panel cluster display on a car.  Works very well for complex indicators.  I have been using LabVIEW for over 20 years and have had to work around the limitations of the GUI just as long.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 12 of 12
(1,124 Views)
