Showing results forĀ
Search instead forĀ
Did you mean:Ā
The problem with Labview!
Hi, when I put  element from waveform generation pallete on the block diagram, the program is closed itself. What does it mean?
Message 1 of 10
(4,843 Views)
This should not happen. Did it happen just once or Is it reproducible?
What is your LabVIEW version? Did you get an error reporting dialog when you restarted LabVIEW?
Message 2 of 10
(4,827 Views)
The Labview version is 8.5. Earlier there were no such problems. Once I incorrectly deleted some files from the Labview folder, maybe it is the cause of the error? I restarted Labview twice, but the error happened.
Message 3 of 10
(4,816 Views)
I think the problem becuase you deleted some files, try to reinstal it agian
Message 4 of 10
(4,811 Views)
I reinstalled Labview, but the error remained.
Message 5 of 10
(4,798 Views)
Why would you delete files from the LabVIEW folder????
Are you talking about the folder for the labview installation (c:\program files\National Instruments\....)
Try to repair the installation.
Message 6 of 10
(4,779 Views)
"The Labview version is 8.5. Earlier there were no such problems. Once I incorrectly deleted some files from the Labview folder, ..."
As I often told my son after he did something that resulted in pain, "Don't do that!". The files are there for a reason.
As Christian suggested a "repair' may help.
Ben
Message 7 of 10
(4,776 Views)
Thank you, I solved this problem.  I go to the register and deleted all files named by National Instruments, then installed Labview again.Now it is working correctly.
Message 8 of 10
(4,740 Views)
Sorry for English: I went to the register!
Message 9 of 10
(4,739 Views)
Again a typo error, I think... Smiley Wink
It is Registry.
- Partha ( CLD until Oct 2027 šŸ™‚ )
Message 10 of 10
(4,708 Views)
