The problem with Labview!
Hi, when I put  element from waveform generation pallete on the block diagram, the program is closed itself. What does it mean?
Message 1 of 10
(4,846 Views)
This should not happen. Did it happen just once or Is it reproducible?
What is your LabVIEW version? Did you get an error reporting dialog when you restarted LabVIEW?
Message 2 of 10
(4,830 Views)
The Labview version is 8.5. Earlier there were no such problems. Once I incorrectly deleted some files from the Labview folder, maybe it is the cause of the error? I restarted Labview twice, but the error happened.
Message 3 of 10
(4,819 Views)
I think the problem becuase you deleted some files, try to reinstal it agian
Message 4 of 10
(4,814 Views)
I reinstalled Labview, but the error remained.
Message 5 of 10
(4,801 Views)
Why would you delete files from the LabVIEW folder????
Are you talking about the folder for the labview installation (c:\program files\National Instruments\....)
Try to repair the installation.
Message 6 of 10
(4,782 Views)
"The Labview version is 8.5. Earlier there were no such problems. Once I incorrectly deleted some files from the Labview folder, ..."
As I often told my son after he did something that resulted in pain, "Don't do that!". The files are there for a reason.
As Christian suggested a "repair' may help.
Ben
Message 7 of 10
(4,779 Views)
Thank you, I solved this problem.  I go to the register and deleted all files named by National Instruments, then installed Labview again.Now it is working correctly.
Message 8 of 10
(4,743 Views)
Sorry for English: I went to the register!
Message 9 of 10
(4,742 Views)
Again a typo error, I think... Smiley Wink
It is Registry.
- Partha ( CLD until Oct 2027 🙂 )
Message 10 of 10
(4,711 Views)
