Text Ring "strings" property updated, but cannot see on Remote Panel
I manipulate the "strings" property of a particular text ring progmatically.  However, the changes cannot be seen on my computers remotely viewing the VI via Remote Panels and a web browser.  The changes can be seen on the computer running the VI.  Is this a known issue?  Is there a work around?
I'm running LabVIEW v. 8.6
Does anyone know if there are any updates to this version?  I've felt like I've been up against bugs in this particular labview version from day 1.
Thanks!
-nic
(3,091 Views)
Accepted by hecmar.arreola
One of my co-workers ran into that issue and it turns out he was writting the string too early. he moved the update of the string to latter in the code and all was OK.
He said it had to do with the Web-service not being up and ready.
That's all I remeber of the top of my head.
Ben
(3,090 Views)
Hi!
This pariticular RING string control is updated first thing when the VI launches.
Thanks Ben!  I'll give that a try.
(3,088 Views)
(3,055 Views)
Yeah .  That worked.  I haven't worked it into my code yet, but the VI automatically runs (it is compiled).  If I start and then re-start the VI after the LabVIEW 8.6 runtime has already loaded w/ the web server running, then the text ring has the correct options (which were assigned progmatically).
(3,053 Views)
