Terminal type of source is "long", sink is "void"
Hi, I have wire to an "Invoke Method" block, but I'm getting the following error shown in the picture.
I was wondering how I can solve it.
Message 1 of 9
(5,155 Views)
Data probably isn't a valid DMA FIFO.  It needs to be a Target to Host DMA FIFO.
Can you zip up your project and post it?  That would be easier to debug.
Message 2 of 9
(5,141 Views)
Sure, please find attached my project files.
Sorry, I couldn't make a ziped file as I got a corrupted file massage!
Message 3 of 9
(5,129 Views)
Yep, you don't have a DMA FIFO in your FPGA target.  So trying to read a FIFO called Data that doesn't exist will cuase this problem.
Message 4 of 9
(5,122 Views)
Nice help. I'll try to solve the problem. I'll ask if I run into a problem in defining the DMA FIFO.
Message 5 of 9
(5,111 Views)
Hi, the following picture shows a block in the FPGA target code.
The documentation of that block says "6. Write the measured data to the DMA FIFO."
I was wondering why this DMA FIFO is not working and how I can define the appropriate DMA FIFO in the FPGA target.
Message 6 of 9
(5,064 Views)
I created a DMA FIFO in the project as shown in the following figure.
Now I'm going to check if it solves the problem.
Message 7 of 9
(5,058 Views)
Accepted by topic author Cashany
If you haven't created a FIFO yet, right-click on your FPGA target and select New->FIFO.  If you have the FIFO created, you can double-click it in the project window to open the properties dialog.
Message 8 of 9
(5,055 Views)
After creating a DMA FIFO in the project explorernow the problem is solved and the wires are not broken as shown in the following window.
Message 9 of 9
(5,053 Views)
