Temperature increase warning
I have a simple temperature monitoring VI and am interested in creating a warning light if the temperature is to increase more than 5 degrees per second. All help would be greatly appreciated.
Dave
Message 1 of 12
(4,962 Views)
Show us the code that you have developed (In 2013 or earlier version or a code snippet).
Message 2 of 12
(4,957 Views)
Yes please post some code.  The simple solution is to only read temperature once a second, and keep the previous reading in a shift register in a while loop.  If current value minus previous value is greater than 5 then use a case structure to change behavior.
Message 3 of 12
(4,944 Views)
hi all...i m doing project about temperature with labview interface arduino...i would like to ask is it possible to send email only one time when the temperature is continuously more than 30 degree celsius for 5 times?..now the problem i faced is when the temperature more than 30 degree, many email will sent.
thx for help...
Message 4 of 12
(4,914 Views)
Yup sure is possible what part of the program are you having issues with? Post what you've tried.
Message 5 of 12
(4,901 Views)
this is what i try...vi 2012
Message 6 of 12
(4,894 Views)
thx for help...
You and the OP are working together? If not why don't you start a seperate thread for your queries.
Message 7 of 12
(4,889 Views)
if i separete it, i need to stop the labview then email just can send...
can i send the email when the labview still running
Message 8 of 12
(4,884 Views)
Do you intend on sending an email every 2 seconds?  Because that is what you code does.  What I think you want to do is to only send an email if a condition is met.  To do this you'll want to use the case structure (not a for loop that runs 1 time) and in the True case does one thing and in the false case does nothing.
Message 9 of 12
(4,842 Views)
He meant that, unless you and the original poster are working together, you should create a new topic so there won't be any confusion.
Bill
CLD
(Mid-Level minion.)
Message 10 of 12
(4,835 Views)
