Tabs
Helo.. I'm using multiple pages in my VI. The problem is,i have created a text in first page,n it is displaying in other pages too. If i delete the text in other page,even the 1st page text is also erasing. how to avoid it..? other pages should be empty,so that i can use it for other functions.
Thank you,
sushmith
(4,465 Views)
Hi sks,
          Please post your VI.
Thanks as kudos only:)
(4,464 Views)
How you are creating the text. Are you typing the text in the front panel outside the Tab and dragging it into the Tab? If yes try to copy and paste the text. It would be good if you post your code.
(4,459 Views)
This is the VI wat i'm doing.
(4,456 Views)
I have typed text on boolean LED. i did that on page 1.
(4,452 Views)
Accepted by sks1990
No its not the right way. You have to use the boolean text of that LED which you can make it visible by Right Click >> Visible Items >> Boolean Text.
(4,441 Views)
Oh!!Very simple..!! Thank you so much...:-)
(4,434 Views)
