search 1D array indices problem
Hello All
I'm trying do my project in labview, but I'm getting stuck
I have 1D array consists of series of 1 and 0 like this -->  1 1 1 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1
but I'm interested on finding the indices of 1 which are only the start and end point of the series
for example: input is 1 1 1 0 0 0 1 1 1 1 0 0 1 1 1
the output should be 0 2 6 9 12 14
Thank you
Message 1 of 15
(4,586 Views)
Sounds like you need a for loop with a couple of shift registers.  One shift register should be used hold the previous value and another to keep the array indecies.  Compare the previous value to the current one, if they are different add the index to the array using the build array function.
What have you tried so far?  Give us some code and explain where you are stuck.
Message 2 of 15
(4,579 Views)
right now i just got the indices of 1's using while loop but i cannot find the indices of each 1's series
Message 3 of 15
(4,558 Views)
I think the way you're searching is flawed.  Like I said earlier, I would look for changes in the array values and store those indices.  I was also playing with your original code and alternated what to search for (1 and 0).  Either solution should work.
I decided to build upon what you already had.  I used the remainder of (i+1)/2 to alternate between searching for 1 and 0.  I will admit that this is not a final solution (I can't just give you an answer).  You will need to account for when the new value is a 0 (subtract 1 from the index) and add the last index if it is a 1 and wasn't already included.
Message 4 of 15
(4,540 Views)
two more ideas:
Message 5 of 15
(4,515 Views)
And one more.
Ben64
Message 6 of 15
(4,507 Views)
ben64,
  That's a great way to do it.  It removes the extra logic I needed in order to get the last element and the need to subtract the index for transitions to 0.  My only thing is that I would put the build array in a case structure to save some memory.
Message 7 of 15
(4,499 Views)
@GerdW wrote:
two more ideas:
Gerd, you might be having a little too much fun with those Pt-by-Pt VIs....  In all seriousness, I really need to look at them.  They seem VERY useful.
Message 8 of 15
(4,495 Views)
Ok, I know this is already solved, but I wanted to have fun.
A bit more obscure, but smaller.
Josh
Software is never really finished, it's just an acceptable level of broken
Message 9 of 15
(4,477 Views)
Yeah, I can tell I've rubbed off on you at least a little bit.  That was my original train of thought.  I abandoned it however because I was trying to help the OP think through the problem.
Message 10 of 15
(4,472 Views)
