Tab Control doesn't execute
Dear all,
i am working on an application with multiple front panels. so i am using tab control to shift from one panel to another.
its working fine for all the cases except one.
i am attaching the pic on that case where a particular page is called and it doesn't get executed.
pls have a look at it and let me know where is the problem
Ritesh
(3,996 Views)
My first guess would be to check the values of your enum, then I'd check that the case is actually executing.  Perhaps I'd do the second one first.  I DON'T KNOW WHAT I'D DO FIRST.
Jim
(3,990 Views)
I have checked both.
the case is executing with no issues.
and the enum values are also correct . its executing perfectly when called in a different event .
Ritesh
(3,983 Views)
Is there anything happening after this event that could be setting it to a different page?  Try putting a Breakpoint after the case structure to see if it changes.
Could you post your program?
Jim
(3,971 Views)
Accepted by LVCoder
What version of LabVIEW?
I have seen a bug in LV 8.0 and 8.2 where:
If you DEFER PANEL UPDATES,
Set the TAB control to tab X
Un-DEFER PANEL UPDATES.
then the TAB control will show tab X in front, but what's on the page is from some other tab.
In other words, it changed the tab doohickey itself, but didn't change the contents.
The workaround was to change the tab via a PROPERTY NODE : VALUE function, rather than a local variable.
I suggest you give that a try.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,955 Views)
Hey Steve,
yeah man updating it by property node worked like charm.
thank u,
ritesh
(3,948 Views)
