subpanels?
Hello, I m working on a visualisation. Bet I wont to work whit more screens.an example: You see the hole project on de main. if you click on the generator you go to an other screen and you see the specific data from the generator.How can I do this? must I work with sub panels or with view? I think with sub panels bet must I copy the hole program to the subVI?
I think that’s a little bit stupid, is it?
Greetz Rutte
(2,979 Views)
Whether you should use popup VIs or subpanels really depends on how much information you want displayed at the same time. With subpanels the subVI's front panel is displayed inside of the main VI. There is no code duplication. If you use subpanels and you want to pop open the subVI that's embedded within the subpanel then you need to first remove the subVI from the panel and then use the VI Server to open the subVI dynamically.
Attached is a modified version of the "Subpanel Viewer" example that ships with LabVIEW. It should get you started with some ideas.
(2,957 Views)
Thanks for the example. Now i can go on.
(2,935 Views)
