11-04-2010 04:02 PM
RIght now the accepted solution is one of your questions. That's not right!
Pick the best answer and, in case of a tie, pick the earliest of the best answers. 😄
11-04-2010 04:16 PM
... and don't forget to give kudos to all answers that were helpful. 😉
11-04-2010 04:16 PM
I am new to this site. I probably took the first answer thinking that every one who replied will get the credit.
1. how can I give you the credit you deserve.
2. Thank you so much you saved me alot of time.
11-04-2010 04:37 PM
You need to go to the Options menu to the upper right of your message that you marked as a reply. Then select Unmark as Solution.
Then you can go to the message that was most helpful to you and mark that one as the solution.
11-04-2010 04:59 PM
liked the 2nd solution, since it uses LV Pink CRLF Platform Indipendent Constant.
Thanks.
11-04-2010 05:36 PM - edited 11-04-2010 05:37 PM
Thanks.
As I pointed out, that's an EOL constant, NOT a CRLF. It only happens to generate a CRLF if you run the code on Windows. Thus, it's platform-dependent, not platform-independent. In fact, the Help for that constant explicitly says platform-dependent.
