TERMINATION CHARACTER
RIght now the accepted solution is one of your questions. That's not right!
Pick the best answer and, in case of a tie, pick the earliest of the best answers. 😄
Message 11 of 16
(1,203 Views)
... and don't forget to give kudos to all answers that were helpful. 😉
Message 12 of 16
(1,198 Views)
I am new to this site. I probably took the first answer thinking that every one who replied will get the credit.
1. how can I give you the credit you deserve.
2. Thank you so much you saved me alot of time.
Message 13 of 16
(1,197 Views)
You need to go to the Options menu to the upper right of your message that you marked as a reply.  Then select Unmark as Solution.
Then you can go to the message that was most helpful to you and mark that one as the solution.
Message 14 of 16
(1,180 Views)
liked the 2nd solution, since it uses LV Pink CRLF Platform Indipendent Constant.
Thanks.
Message 15 of 16
(1,173 Views)
Thanks.
As I pointed out, that's an EOL constant, NOT a CRLF. It only happens to generate a CRLF if you run the code on Windows. Thus, it's platform-dependent, not platform-independent. In fact, the Help for that constant explicitly says platform-dependent.
Message 16 of 16
(1,164 Views)
