How to Transition to a Specific Case from an Event Structure Trigger?
Can someone help me troubleshoot my program. I've attached my VI so you can follow along with what I am describing. So here is the scenario:
I have a program that consists of four test states, stop test, request test info, and end program (cluster of 7 booleans). Each test state sends a serial command to a DUT, receives ACK packet, opens relays which disconnects the serial connection and DUT will continuously test by itself. If the user wants the end the test early, they can hit the "Stop current test" which will close the relay reestablishing serial communication, wait 10 secs for device to enumerate on the PC, and then send the serial command to stop the test. From here, the user can request test information from the DUT by hitting the "Request info" button.
So my dilemma is when I try to implement a time limit for cases 2 - 4. For case "M1-Idle", the program works flawlessly since there is no time limit. The program will send the serial command, transitions to "Open Relay" case and switch back to the "Idle" state to wait for the "Stop" command. The user has to hit stop whenever to close the relay, request info and/or continue testing.
For case 2 through 4, there is max time limit of 3 hours. This is where I am having difficulty opening the relays and then entering the timer count down case structure to start the timer. Question is, if I am using the Event Structure to trigger on a user action event (i.e. user presses "Run M2-Normal" - Menu.M 2: Value Change) it sends the command and move on to "Open relay" to break the serial connection as intended. Since the next state of "open relay" is "Idle" how can I add case selector to select "M2 - Timer" instead of "Idle" given that it was based on user selection of "Run M2" event?
Is that even possible? I tried using the feedback node on the state enum but its coming from the case state and not the event state so it doesn't enter properly into the timer state. Any help or ideas is greatly appreciated. Thanks in advanced.
Main_Working_Copy.vi is the main portion of the program.
Henry
Message 1 of 1
(2,563 Views)
