01-10-2008 09:24 PM
01-11-2008 02:29 AM
Hi Chris,
The run-as option under XP is a way to go, although it does add another security issue to a system that may be bes to try and avoid if possable. I did install the program yesterday under 1 of our Lab PC's and was able to run it and read from the TDMS file (with the file in the same folder as the .exe) - this worked for both source and executable, and worked under superuser and a user with "Restricted Access" - Would it be possible for you to get the exact user permissions from your customer regarding there restricted access account setup?
I shall run the program again today under the Guest account (as I know it to be more locked down than Restricted Access users).
01-11-2008 08:21 AM
01-14-2008 08:49 AM
01-15-2008 02:51 AM
Hi Chris,
I've been unable to reproduce this issue under restricted access, it works just the same as under admin users. Does the company have any additional restrictions on users that may be causing this problem?
01-15-2008 08:14 AM
04-17-2008 02:47 PM
04-23-2008 09:19 AM
04-23-2008 09:44 AM
04-24-2008 02:47 PM
