TCP/IP xml command
Hello.
I'm trying to connect measurement device vis TCP/IP communication. Since the manufacturer doesn't provide command set package, I could capture the packet while bundle software was running with the device. The stream seems to use xml codes. Red code is that PC sends message, and Blue code response with values. I created VI's accoding to simple example, but the communication failed.
Anyone can help/guide me resolve this communication?
Thank you in advance.
Gino
18819iBEF92A2DC9381D24
18821i5BFA3EF582D15DDA
(5,452 Views)
Please be a bit more specific when you say "the communication failed". How it fails may help point to how to make it work.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(5,424 Views)
The Error message says "Error 56 occurred at TCP Read."
(5,404 Views)
Error 56 is a simple timeout error, and in and of itself may be harmless. Are any bytes received in your "read buffer" string indicator?
Here's a helpful tip when you're troubleshooting errors: on the menu bar, choose "Help >> Explain Error..." and type in 56 to the dialogue.
(5,394 Views)
Error 56 occurred at an unidentified location
Possible reason(s):
LabVIEW:  The network operation exceeded the user-specified or system time limit.
The string input was considered to be correct according to the TCP stream indicated in picture above. But, it may be additional work to do communicate.
Anyone help me?
(5,377 Views)
Try appending a CR or LF (or both) at the end of the string.
(5,370 Views)
It doesn't work at all.
(5,356 Views)
