NI DAQ detect
Whever i try to detect NI hardware through labview it shows  below error:
"Error -2147220712 occurred at an unidentified location
Possible reason(s):
(Hex 0x80040318) Internal error: The client has failed to connect to the configuration server, possibly because the server is too busy or has run into a communication error. Please note the steps you performed that led to this error and contact technical support. "
(3,705 Views)
Hi www.ni.com,
which function do you use? Can you show your vi?
Mike
(3,702 Views)
To add some questions to MIke's:
- What is the hardware you want to use?
- Do you have access to the hardware using MAX (Measurement and Automation Explorer)?
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,697 Views)
Hi mike,
This promblem getting solved.
by the way thanks for asking.
(3,694 Views)
Can you also share what you did to solve the problem?
(3,541 Views)
Double post plz ignore
(3,541 Views)
