SystemExec.vi
Mandriva 2006 2.6.12 (is necessary) w/ labview 8.6 installed. daqmxbase 3.2.0.
i'm use systemExec.vi to send string commands to include data in postgres DB. After six hours running, the systemExec.vi stay freeze (verified by highlight option-debug mode) and dont return error, the green arrow point to systemExec in execution yet. But this procedure already done several times before freeze. Why freezed after long time running?
This problem occur in application.exe running, but in development enviroment dont occur.
The memory usage is equal when running application.exe or development enviroment.
thanks for help.
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
(3,006 Views)
Dear Leonardo,
I suggest you do the follow, during the freeze time, can a terminal window be opened and run the command that LabVIEW is trying to write through the System Exec VI?
Let me know if you need further information.
Regards
Jailton
(2,923 Views)
The problem occur too in development environment when running.
I dont undersand because the SystemExec.vi is running (freeze execution inside, look to green arrow) with boolen entry until to completion? changed to FALSE.
look attached file.
Thx for help.
(2,854 Views)
