How can I convert an ASCII string of variable length to a HEX number?
I read data from the serial port 5 times in a second (while loop) and the number of bytes read varies every time.
The data comes in as ASCII string, and I can see the HEX representation if I connect a HEX string indicator, but I need to permanently convert data to a HEX number.
How can that be done?
(3,712 Views)
Like This.
Ton
My LabVIEW Ideas
(3,703 Views)
TNX! But what will happen if i get 00 in the middle of the hex string. Will that be left out?
(3,681 Views)
No, if the string contains a NULL byte (0x00) then the output string will show 00.
Ton
My LabVIEW Ideas
(3,677 Views)
(3,653 Views)
