LabVIEW base and LabVIEW professional?
What is the main different between LabVIEW base and LabVIEW professional?
(3,335 Views)
Check this discussion
See what is the difference here
Message Edited by muks on 05-27-2010 05:02 PM
(3,332 Views)
Thank you,
Just I question, if I want to buy LabVIEW Base for data acquisition and data-logging applications with NI-USB -5132 maybe some basic data analysis , it is ok or it will required full version?
(3,303 Views)
It really depends on what you mean by "data analysis". If you plan to write your own data analysis code, sure it's fine. Otherwise, all of the math, analysis, and signal processing VIs are not in the Base edition
(3,284 Views)
