System dir
Hi Guys;
           Is there any way to get the disk where the OS(windows xp/2ooo) was installed? , and the path where Labview was installed?
thanks
Message 1 of 8
(4,560 Views)
HI,
You will get windows directory path VI on http://zone.ni.com/devzone/cda/epd/p/id/3080
For getting LabVIEW directory path see snapshot as attached
Hope this helps
Santosh
Message Edited by SanRac on 06-04-2009 12:03 AM
Message 2 of 8
(4,547 Views)
Find the VIs to get windows path.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 3 of 8
(4,539 Views)
Hi Santosh,
It wont work for an EXE built usign LV.
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 8
(4,516 Views)
Hi Parthabe,
Yes you are right, so in this case I think we can use "Defualt Directory" function, I am not sure how it will respond with build.
Thank  You.
Santosh
Message 5 of 8
(4,508 Views)
Is SanRac & San403 the same person or different... ?! Smiley Indifferent
Message 6 of 8
(4,502 Views)
Its same, actually was logged in to other account Smiley Very Happy
Alias will be anything you can call me Santosh
Message Edited by SanRac on 06-04-2009 06:06 AM
Message 7 of 8
(4,500 Views)
Accepted by adobefree@gmail.com
My guess was correct! Smiley Happy
When I looked into that profile, it showed offline. Smiley Wink
So, I was just curious to know... Smiley Very Happy
Message 8 of 8
(4,496 Views)
