Can't delete LabView process in the Task Manager
I closed TestStand, closed Labview.  However, when I look in the Windows Task Manager I can see a LabView process still running ( LabVIEW.exe, 116,124K).
Is that Normal?
Is it possible to close it?  (End Process does not work...'Access Denied')
Rafi
(3,054 Views)
You need to exit out of LabVIEW the proper way from TestStand, assuming that's what you want to do:
How Can I Close LabVIEW after my TestStand Sequence Executes?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,044 Views)
