System Exec.vi
PC is running Windows10.
I'm usingLabVIEW 2017.
I  have installed PdfCreator v, 4.4.0  (free version).
When i run
               PDFcreator-cli.exe
from a Windows shell, I got:
But if I run the same sw using "System Exec.VI" I got:
Can anyone give me some hints?
Message 1 of 9
(3,775 Views)
Have you tried putting 'cmd /c' at the beginning of the command line input?
aputman
Message 2 of 9
(3,750 Views)
You could use the example that is provided by NI:
I believe aputman is correct on the need for cmd /c to make this work.
Tim
GHSP
Message 3 of 9
(3,730 Views)
Ty aputman.
 I think you are right, but putting "cmd /c" before the .exe name, don't change the result.
Message 4 of 9
(3,691 Views)
Hey aeastet.
I forgot to check the examples!
Anyway, I posted  a simplified version of the problem.
LabVIEW create a batch file (.bat), in which some files are moved in a folder, and then  PDFCreator-cli.exe merge some .pdf files.
LabVIEW call System Exec.vi to run the batch file.
When I run LabVIEW .vi,  i got that files are correctly  moved as I expected, but .pdf are not merged.
The call to System Exec.vi, always return in standard error:
Unhandled Exception: System.IO.IOException: The handle is invalid.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.Console.GetBufferInfo(Boolean throwOnNoConsole, Boolean& succeeded)
at pdfforge.PDFCreator.UI.CLI.Program.ConfigureParser()
at pdfforge.PDFCreator.UI.CLI.Program.<Main>d__0.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at pdfforge.PDFCreator.UI.CLI.Program.<Main>(String[] args)
Running the batch file manually, doubleclicking on it, always works fine.
bye
In the standard error output there is always the same message:
Message 5 of 9
(3,679 Views)
Add the correct path as Start/default folder. Since Windows 7 it's been pickier about that.
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 9
(3,661 Views)
Hi Yamaeda,
I don't know exactly what "correct path" mean, but I think that the problem can be related to  access privileges to system folders..., so I tried copying the full tree of
     c:\program files\PDFCreator
to
    d:\PDFCreator
Then i ran the PDFCreator-cli.exe from the new path, but I got the same error.
ty
bye
Message 7 of 9
(3,620 Views)
Other alternative to consider:
1. Create a batch file, put your command in it.  Make sure it works in Windows.  Call the batch file using System Exec.vi
Or
2. Create a shortcut, configure it properly (for example: run as admin, etc.).  Call it in System Exec.vi.
George Zou
Message 8 of 9
(3,599 Views)
@NoShelter wrote:
Hi Yamaeda,
to
    d:\PDFCreator
ty
bye
Sorry for the delay, i've been on vacation. 🙂
In your examples, try setting D:\PDFCreator as Working directory input.
Qestit Systems
Message 9 of 9
(781 Views)
