NIST REFROP - Thermodynamic calculations in Labview
I currently use Labview 2018 64 bits. NIST REFPROP 9.1 is also installed.
I have to write a VI which can access to thermodynamic properties of R134a & R1234yf fluids and perform calculations.
However, I do not find any Labview package for Refprop.
I saw some Labview Refprop wrappers available for Labview 2021 and Refrop 10.0.
Should consider an upgrade to be able use these wrappers ?
Is there any other solution (in order to run thermodynamic calculations) compatible with my current software versions ?
(456 Views)
Hi MSIEV,
I used RefProp with LabVIEW 2014 and 2017 successfully, so you don't need to upgrade. I used LabVIEW-32bit, this might be an issue with your 64bit version!
Other solutions I used are FluidProp, which was used as the wrapper around RefProp to employ a more simple API.
(453 Views)
Hello GerdW,
Thanks for your reply, I will investigate for FluidProp solution.
(413 Views)
