Syncing 2 Agilent 33220a Function Generators Using LabVIEW 2015
Hi Guys,
Hoping someone has done this before but I can;t imagine it's very common. I have 2 Agilent 33220 function generators that I need to sync using arbitrary waveforms and opposite phase. i.e. When the first one is outputting, the second one isnt and vice versa.
At the minute, I only have the need to use one at a time so have never had this issue before. Is there a need to use an external trigger source or is it possible to do this solely with LabVIEW code? I have found a tutorial from Agilent on Youtube on how to do it and have been trying to follow the instructions and find the appropriate functions in LV but I can't seem to find some. Namely the "#Cycle/Infinite" key and one or 2 others. Thanks for your help.
Tutorial is here: https://www.youtube.com/watch?v=NqqbfvuWQxA
(3,898 Views)
When you say "find the appropriate functions in LV" do you mean you downloaded the Agilent LabVIEW drivers and you can't find a pre-made VI to do every step you see in the video?
I've only ever used a 33210A personally but I discovered that some of the functions it supported were listed in the programming manual but didn't get programmed into the pre-made VIs that you can get through the instrument driver download.  You may need to download the programming manual and find the remote commands and implement them yourself.
(3,876 Views)
Apologies, yes that is what I mean. As far as I can see, there isn't a pre made VI for every step in the video. I will try inputting the commands by myself and see where that takes me. Thank you.
(3,837 Views)
