How do I plot a surface graph such that color ramp is defined at every point on the z axis
I intend to plot a cylinder using a 3D surface graph (matrix). The issue is that every row of the radius matrix has different min and maximum values. I would like to use a case structure to look at the range of radius values in each row and set my color ramp cluster values accordingly. This would then mean ( 2D arrays for color ramp index and color ramp Array ) which I do not think the property node would accept. Also I observed that currently, the ramp takes my z values instead of my Y ( radius) values for the color ramp. how do I change this?
[BADGE NAME]
(4,824 Views)
it is possible to programmatically customize a (vector) 3d scatter plot's color mapping:
http://forums.ni.com/t5/LabVIEW/How-to-display-4d-data-within-a-3d-scatter-plot/m-p/2508388#M763667
(4,788 Views)
This thread is an index of 3D graph posts.
The thread that are linked in that thread have some code that shows how to use the 4th dimension as the color. So for your question that means reformatting your data properly and providing a color scale.
Have fun!
Ben
(4,786 Views)
Thanks Ben and Alex. Can anyone confirm if the color matrix input for the Parametric graph works in Labview 64-bit 2015? Considering that it has only two color map modes "absolute/ relative ( no color spectrum)?
[BADGE NAME]
(4,765 Views)
I can not help with the new version of the 3D graph. I tried it out right after it came out as public beta (with little or no documentation) and lost all interest.
Sorry, that I can not help more.
Ben
(4,747 Views)
