If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Symbolic Paths
I'm running different versions of LV in the same PC and my search directories seem to be messed up, is there a way to take a look at the absolute path of the symbolic paths(<vilib>, <usrlib>, etc)???
Thanx
(3,148 Views)
Not really, what makes you think there's something wrong?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,143 Views)
When I am mass compiling in LabView the directory changes are not being saved in the individual VI's so every time I compile and then re-compile a folder, all the same directory links are performed again. Adding the directories to the search paths has not work so far so I am thiking there is a problem with having two versions of LV installed....
(3,125 Views)
Are the VIs by any chance write protected (read-only) like if they were copied off of a CD or something?
Mike...
LabVIEW Champion
(3,111 Views)
I am a little confused by the trouble that you are having. What do you mean when you say that you "mass compile, the directory changes are not being saved in the individual VIs?" When you "compile and then recompile a folder," what do you mean that "the same directory links are performed again?" By mass compiling, your VIs will be opened and saved in a different version, but paths to your own subVIs will not change. Do you have a VI which you are compiling in multiple versions of LabVIEW? Can you give me a step-by-step for seeing the same problem that you are experiencing?
I have versions 7.0, 7.1, 8.0.1, and 8.2.1 all living happily on my machine and I do not experience strange behavior when I mass compile any of my LabVIEW directories. I am sorry that I have misunderstood your problem. If you can describe the scenario for me, I can suggest how to avoid it. Thanks,
Mike Duffy
Applications Engineer
(3,098 Views)
