Subvi front panel in Webserver
i've made a VI (an oscilloscope) that in his while cycle call 2 sub-vi to obtain the waveforms to show on his display. The two sub-vi generate a waveforms and don't have a while cycle because they run through the call of the main VI. The program work perfect in labview or in EXE, but i want to put him on an html page and here is the problem. The main VI work well but the front panel of sub vi don't open, i wrote two link in the html page of the main vi, like this one:
<a target="new window" href="SubVI01.html">SubVI Title</a>
 and when you click the link the front panel of the sub vi shows, but there isn't any comunication with the main vi. How can i run this vi properly in the webserver mode?
(3,162 Views)
Hi!
I suggest you this document
http://digital.ni.com/public.nsf/allkb/E313D1D88CE14FDA86256E6A006B28ED?OpenDocument
Let me know if it solve your problem.
(3,129 Views)
Bronzacuerta - when I click your link, I get a page that says "Error You are not authorized to view this document"
(3,122 Views)
I guess the correct link is : http://digital.ni.com/public.nsf/allkb/BD9862FF7E3D53F386256C7C00836202?OpenDocument
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
(3,117 Views)
There is a problem with the document that you have linked, condition number 3 : The subVI is not set to be re-entrant. This can be set in the Execution tab of VI Properties. But in this way only one user can use the vi or if i set the main VI re-entrant is enough to make the all project re-entrant on web server?
(3,112 Views)
