Using Rener Window for 3DWaterfall graph in executable
I'm using LabVIEW v11 on 32 bit Windows XP.
When I'm working in the development environment I can right click on the 3D Waterfall graph and bring up the Render Window, this works fine and is a much better display than the main 3D indicator. Unfortunately now that I've built the executable this option to bring up the Render Window isn't there.
Is there anything like a dll that I need to include in the build options. I've tried searching, but I can't seem to find much on the Render Window.
Ian
(2,999 Views)
Hi IanW,
When VI is built in application, it is always in run-mode. We did not make the render window available run-mode.
(2,993 Views)
Thanks for the update.
That's a pity. I've already shown the user, he was very impressed, now I will have to disappoint him.Smiley Sad
Regards
Ian
(2,986 Views)
Sorry to bump an old thread, but you can still get the render window even in run mode. See
http://forums.ni.com/t5/LabVIEW/3D-Graph-Render-Window-Programmatically/m-p/952615
(2,958 Views)
