Subtract the mean of a matrix from each element
I am doing principle component analysis I have an original real matrix feeding in to a the covarience matrix which gives the mean out at one of the nodes and want to subtract that from each element of the original matrix to form a new matrix. If this is to hard to connect the mean out of the covariance matrix is there a way of just finding the mean of the original matrix and subtracting this from each element in the matrix to form a new matrix.
Thanks for your help
Canalian
(4,186 Views)
The Subtract primitive on the Numeric palette is polymorphic.  You can subtract a scalar from a matrix or an array.  The result is also a matrix or an array with the scalar value subtracted from each element.
Lynn
(4,174 Views)
Hi Lynn,
Thanks for your quick reply. I must have been tired last night I realised that the problem is that I have a 1d matrix comming out of the covariance matrix and I am trying to subtract that from a each element of a 2d matrix, but I don know how to do this. I have attached the code of what I am trying showin the broken wire.
Your help is greatly appreciated.
Nick
(4,162 Views)
Accepted by topic author Canalian
The mean of a 2D array is simply the sum of all elements divided by the number of elements (=the product of the dimensions).
All you need is the following (works equally well for arrays with more than 2 dimensions):
(4,157 Views)
Thanks that is really appreciated
Nick
(4,150 Views)
