Subpanels and popup question (labview 7.0)
I am not sure what I am doing wrong but it doesn't seems to work for me.
 Can you upload the vi you made using labview 8.0 so I can see it?
Krispiekream
Message 21 of 25
(1,393 Views)
Accepted by topic author krispiekream
I modified your code using LabVIEW 2017. That's all I have installed on this machine. You can go to the Version Conversion board and have someone there change it to LabVIEW 8.0.
You did not include the "limit checker_new.vi" so I just put a couple of Boolean constants there in its place. I got rid of a lot of code that was unnecessary and modified the code that was missing/wrong. Again, this works in 2017 and it should work in 8.0.
Message 22 of 25
(1,386 Views)
My friend came up with this solution that seems to work in Labview 7.0. Using Event Structure for KEY DOWN & ENTER KEY. It works when I am testing it here.
Now my other problem is running SUBPANELS within SUBPANELS. But that's another thread of its own 😞
Krispiekream
Message 23 of 25
(1,382 Views)
Well, I forgot how difficult it is to work in LabVIEW 7.0 once you are used to "modern LabVIEW" (I'm currently doing most of my work in LabVIEW 2016).
I thought that the idea was to be able to "launch" a sub-VI and have it run in a sub-Panel, and also be "stoppable".  This is so easy to do with Start Asynchronous Clone, and quite a challenge to do with VI Server (particularly if you haven't used it in 6-8 years).
This is the Caller.  It will use a Notifier to stop the Sub-VI when the Stop button is pushed.  We start the Sub-VI first (as it has an OpenG "Fit FP to largest Decoration" function to make the Window nice) then insert it into the sub-Panel.  Hmm -- I see opening it in LabVIEW 2016 for purposes of making these pictures has distorted things a bit, but the VI's themselves will be attached (if I remember ...).
Here is the FP for the sub-VI -- notice the Raised Frame Decoration surrounding what we want to see in the Front Panel.  I can't seem to get the Block Diagram to fit with these new-fangled Windows, so I'll just attach the two LabVIEW 7.0 files.  If you don't have LabVIEW 7.0, trust me that this works ...
Message 24 of 25
(1,373 Views)
that works!
Its a lot easier than the method I came across.
Thank you so much. I will try to use this method.
THANK YOU AGAIN!
Krispiekream
Message 25 of 25
(1,364 Views)
