Graphing multiple analog channels on xy graph
Good morning all. Need help from any of you that may have the answer to my question. I need to graph multiple analog channels on a xy graph. I am measuring voltage from a device and I am taking 1000 samples per second at a rate of 10,000 hertz. I would like to graph each sample taken vs its corresponding time at which each happen on a xy graph. How do I get the time so that I can plot it on a xy graph? The code sample I provide it shows a timer but when I run the program, it does not work properly. Looking forward to hear from any of you!!
Isidoro Vazquez
(3,007 Views)
Hello, since your question refers to LabVIEW you should post it to the appropriate board: this one is dedicated to LabWindows/CVI
(2,971 Views)
Accepted by topic author Chulito
You didn't include all the dependent subVIs.
What does this mean?  Are you sampling at 1KHz or 10KHz?
Anyway attached is an example of what I think you want.  I am generating some random data at 1Khz, then pulling out the X and Y values from it, adding it to a circular buffer of 3,000 samples (this means it will fill after 3 seconds) and then graph it on a graph that has the X axis configured to be an Absolute time scale.  The 3 seconds buffer is arbitrary but you don't want to fill it forever or your PC will crash running out of memory.  This combined with subsampling is a good way to keep from using up more memory than is needed.  I mean If you put 10,000 samples on a graph, you can't see all 10,000 samples, your monitor isn't that many pixels wide.
(2,933 Views)
Thank you guys you are awesome. This helps a lot!!
(2,923 Views)
