Sub-panel buttons do not trigger evets when their state is changed from the main panel
I want to control a button in a sub-panel that triggers an event. When I change the button's state in the main panel, the button's state changes, but doesn't activate the event.
I used this example https://forums.ni.com/t5/LabVIEW/subpanel-control-button-programmatically/m-p/2729895#M807809, and I got the same outcome as using global variables.
What am I doing wrong?
Thank you in advance.
(1,017 Views)
When you use the "Value" property to change the value of a control programmatically, no event will be generated. You need to use the property "Value (signaling)"  if you want an event being generated.
Rolf Kalbermatter  My Blog
(978 Views)
