It is ok to generate TTL signal using a counter DAC source?
I would like to know if it's ok to use Dac counter source (for example a counter on the USB-6341) to generate a periodic 5V TTL as a trigger for an instrument. It works but it would be possible to use the frequency generator function.
Is there any preferences?
Thank you,
(971 Views)
Accepted by topic author labfun
Hi labfun,
Generating (TTL) pulse trains is a core function of counters on DAQ cards, so it's ok…
(958 Views)
