Sub Panel in Application Builder
My VI has a sub panel with with a sub vi front panel displayed in it.  When I build my application the sub panel is no longer visible.  How do I get it to show up?
Message 1 of 11
(6,543 Views)
there is a simple subpanel.vi example you can take a look at.
its in the examples.
Krispiekream
Message 2 of 11
(6,534 Views)
When I run the simple subpanel vi I see the graph but when I build the simple subpanel vi the application created does not show the graph.  How do I build it to include the subvi?
Message 3 of 11
(6,522 Views)
oh,
i do something like this
you right click on the front panel where the subvi is at and create a property node (VALUE)
change VALUE to read and click on create constants to create the subvi constant on the front panel.
try it, it should work.
Krispiekream
Message 4 of 11
(6,518 Views)
Thanks but that still did not work.  First of all value is not an option for the property node.  I tried visible but that did not work.  I am using LabView 2009 - I suspect you are giving me instructions for LabView 7  .  Anybody know how to do this in 2009?
Message 5 of 11
(6,509 Views)
Hi John,
are you including the subVI in the application?
Message 6 of 11
(6,504 Views)
No - how do I do that?
Message 7 of 11
(6,501 Views)
as far as i know,
a subpanel is a screen where you can see other subvi in your main panel.
so you need to create a subpanel screen on your main screen.
then you would use something like this.
 can you post the code and see what subvi you want to add to the frontpanel so we can take a look at it? it would be faster.
Krispiekream
Message 8 of 11
(6,494 Views)
When I run the VI under labview it works fine - my subpanel shows what I want.  It is only when I build a standalone application using application builder that I have problems.  The standalone application does not show the subvi.
Message 9 of 11
(6,490 Views)
Accepted by JohnP
Message 10 of 11
(6,481 Views)
