String of binary to text
Hi there,
I was wondering whether you could convert a string of 01110010010 (for example) into text, so if I entered 01111110 I would get ~.
Christopher
Message 1 of 15
(5,755 Views)
If i understand you right, you want to convert a number to its ascii representation, right?
Message 2 of 15
(5,753 Views)
Message 3 of 15
(5,750 Views)
You can also see this. https://forums.ni.com/t5/LabVIEW/Converting-a-binary-string-to-a-number/m-p/33935
You'd use scan from string if you have a binary string.
Message 4 of 15
(5,743 Views)
How is that value being entered?  Is it a single byte with Binary radix/display?  A string of just 1s and 0s in ASCII?
Assuming a single byte, the use Build Array and Byte Array To String.
If the string of 1s and 0s in ASCII, then I would use Scan From String with "0b8" as the format to convert to a U8.  Then you just use the Build Array and Byte Array To String to get your character.
Message 5 of 15
(5,722 Views)
Oh no I mean like an actual string. So it would be a string (pink) with 1s and 0s inside it. Not sure how you would convert that to a text string.
Message 6 of 15
(5,705 Views)
This is what you need.
Message 7 of 15
(5,703 Views)
That only works for the first letter. So the way my system works is it takes in a bunch of binary values which no spaces in between for each character, so for example 0110100001100101011011000110110001101111001000000001010 would be the binary string which I want to convert to hello.
Message 8 of 15
(5,700 Views)
Whats the source of the data being streamed & size of each data packet? I am assuming its an unsigned 8-bit? You'd have to parse your data packet based on the packet size and then apply the VI that i shared in my previous post.
Message 9 of 15
(5,690 Views)
Accepted by programlad19
Message 10 of 15
(5,685 Views)
