String of binary to text
It's just a string... the entire system I'm talking about is a receiver for a signal. So it takes the signal's Y values, determines whether they're a binary 1 or 0 and appends a 1 or 0 to a binary string to give the resulting output. From there, I just want to take that string of binary numbers with no spaces and write that as ASCII text.
Message 11 of 15
(1,149 Views)
What's that "x 30" and the 4.x typecast? I'm not sure where to get them.
Message 12 of 15
(1,147 Views)
Accepted by topic author programlad19
Here is another solution:
Message 13 of 15
(1,141 Views)
I think Darin's solution doesn't properly handle the line feed at the end of the string "0110100001100101011011000110110001101111001000000001010".
Message 14 of 15
(1,135 Views)
There is a typo, the correct string to have a newline at the end is
01101000011001010110110001101100011011110010000000001010
There is a subtlety that adds a null to odd length strings, I would fix it like this:
The x30 is the ascii value (hex 30, decimal 48) for '0', simply an integer constant.
You get the 4.x on Type Cast by using the right-click menu, it treats boolean arrays the old-fashioned way, ie. as bits.
Message 15 of 15
(1,118 Views)
