If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
08-28-2013 01:42 PM - edited 08-28-2013 01:43 PM
So I ran into this "bug" not long ago.
Normally, when select the scroll bar on any string indicator in labview and drag it up and down, the text moves accordingly.
However, when you use the mouse wheel to scroll and the string indicator is not selected (only the mouse cursor is over the indicator), the text just overlaps endlessly until one moves the mouse cursor over the scroll bar. See the attached image.
This looks like a front panel refresh problem and is not the first one I encounter.
Is anyone else experiencing this issue?
Is it a known bug?
Please let me know!
PS: LV 2012 SP1 f4 is what I am using.
08-28-2013 01:47 PM
I tried it and it worked fine for me. Could you whip up an example really quickly so we can fool around with it and repeat your results?
Off the top of my head, I'm thinking this could be a display driver or (remotely possible) a mouse driver wheel implementation issue.
thanks!
08-28-2013 01:59 PM
Hi Billko,
Thanks to you, I just found out that it is only when the STRING indicator's background is set to TRANSPARENT that it doesnt work. Thats mucho sad 😞
Attached please find the example VI.
08-28-2013 02:47 PM
@JorgeF wrote:
Hi Billko,
Wow - VERY reproducable. 🙂
Unfortunately I have no answer. Sounds buggy to me.
08-28-2013 02:50 PM
I worked around this issue:
I simply used the same color as the panel's background in the string indicator.
It works.
Thanks Billko
08-28-2013 02:50 PM
It "blurs" for me, too. Unless the indicator has key focus, which highlights it.
08-28-2013 02:50 PM
Furthermore, customizing the control and putting in a background picture doesn't help. And it seems that the control refreshes itself when the mouse moveseither onto or off of the control.
08-28-2013 02:51 PM
That is exactly what happens 🙂
I'm glad to see I am not the only one with the issue.
Thanks all!
08-28-2013 02:52 PM
Thanks all!
I'm kind of sad you aren't. 😉
LOL
08-22-2019 10:47 AM
Sad to see that this is still a thing in 2018 😞
Of course the simple work around is to *not* use transparency.
