String indicator vertical scroll-bar BUG?
So I ran into this "bug" not long ago.
Normally, when select the scroll bar on any string indicator in labview and drag it up and down, the text moves accordingly.
However, when you use the mouse wheel to scroll and the string indicator is not selected (only the mouse cursor is over the indicator), the text just overlaps endlessly until one moves the mouse cursor over the scroll bar. See the attached image.
This looks like a front panel refresh problem and is not the first one I encounter.
Is anyone else experiencing this issue?
Is it a known bug?
Please let me know!
PS: LV 2012 SP1 f4 is what I am using.
Jorge
Message 1 of 13
(5,321 Views)
I tried it and it worked fine for me.  Could you whip up an example really quickly so we can fool around with it and repeat your results?
Off the top of my head, I'm thinking this could be a display driver or (remotely possible) a mouse driver wheel implementation issue.
thanks!
Bill
CLD
(Mid-Level minion.)
Message 2 of 13
(5,312 Views)
Hi Billko,
Thanks to you, I just found out that it is only when the STRING indicator's background is set to TRANSPARENT that it doesnt work. Thats mucho sad 😞
Attached please find the example VI.
Jorge
Message 3 of 13
(5,307 Views)
@JorgeF wrote:
Hi Billko,
Wow - VERY reproducable.  🙂
Unfortunately I have no answer.  Sounds buggy to me.
Bill
CLD
(Mid-Level minion.)
Message 4 of 13
(5,290 Views)
Accepted by topic author JorgeF
I worked around this issue:
I simply used the same color as the panel's background in the string indicator.
It works.
Thanks Billko
Jorge
Message 5 of 13
(5,288 Views)
It "blurs" for me, too. Unless the indicator has key focus, which highlights it.
Message 6 of 13
(5,287 Views)
Furthermore, customizing the control and putting in a background picture doesn't help.  And it seems that the control refreshes itself when the mouse moveseither onto or off of the control.
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(5,285 Views)
That is exactly what happens 🙂
I'm glad to see I am not the only one with the issue.
Thanks all!
Jorge
Message 8 of 13
(5,284 Views)
Thanks all!
I'm kind of sad you aren't.  😉
LOL
Bill
CLD
(Mid-Level minion.)
Message 9 of 13
(5,281 Views)
Sad to see that this is still a thing in 2018 😞
Of course the simple work around is to *not* use transparency.
Message 10 of 13
(4,530 Views)
